Discussion topic: Car ev dropping connection
This message was authored by: dms1977
I am not getting a strong signal to my car ev charger, the device keeps losing signal going online, is there a WiFi booster option to strengthen my signal
Re: Car ev dropping connection
@dms1977 What sky hub do you have, white or black, also consider doing a powerline that may be more effective for what you require!
Powerline Adapters | TP-Link United Kingdom
This message was authored by: Nav8
I'm not getting strong signals to my car ev charger
@Nav8 WiFi outside a property is often difficult as external walls are usually double thickness so reducing the WiFi signal significantly. You could buy Sky's WiFi Max bundle and ask for an extender you could place inside your home near as you can get to the charger which only requires minimal bandwidth unlike a camera. Alternatively you could buy a cheap 2.4GHz WiFi access point and place that similarly ideally near a window overlooking the charger.
