Discussion topic: Cannot connect my ring doorbell to sky max
This message was authored by: 232
Message posted on 01 Nov 2024 12:38 PM
Have just got Sky Max and I can't connect my ring doorbell to it. Have tried umpteen times and it still doesn't work.
Find out more
Message posted on 01 Nov 2024 12:43 PM
Re: Cannot connect my ring doorbell to sky max
You may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub administration settings in the My Sky app. It's also possible to use those settings to temporarily disable the 5Ghz band.
