Discussion topic: Cannot connect echo dot due to captive portal
This message was authored by: 4133charl
Message posted on 20 Mar 2024 08:52 AM
Hi,
I was trying to set my up my dad's echo dot, but the Alexa app stated that it could not connect as there was a captive portal. Does anyone know how I can fix this? Thank you
Find out more
Message posted on 20 Mar 2024 10:23 AM
Re: Cannot connect echo dot due to captive portal
The Alexa app is mistaken: there is no captive portal functionality hosted by a Sky Hub.
Message posted on 20 Mar 2024 10:39 AM
Many thanks for your help. I will try deleting the Alexa app and starting again.
