Discussion topic: Can you use a tplink av600 with 1gb broadband I upgraded to 1gb
This message was authored by: Aidan471
I was on 70mb using a tp link av600 and could get signal to mini box out in garden room I got upgraded to fibre to the home 1gb and have no signal in garden room since tried rebooting resetting everything just see if the av600 is compatible with 1gb broadband
Re: Can you use a tplink av600 with 1gb broadband I upgraded to 1gb
@Aidan471
To be clear, were you using a pair of those adapters for Powerline networking, or a single unit as a WiFi extender?
Avatar for Aidan471
Re: a pair one in to router and other out in garden room
A pair one in the router and other out in garden room had my q mini connected to it
@Aidan471 assume you have the new white Sky Max hub so I suspect the issue is with an incompatibility with the Sky Q mini rather than the powerline adapters. You can try a wired device in the garden room to test that theory or use a different WiFi access point. However while Q minis can work with the Sky Max hub that is where they are linked by WiFi to a main Q box they definitely cant be connected to the hub's own wifi and the same may be true of ethernet but I dont know thst as a fact..
