Discussion topic: Can’t connect to WiFi
Message posted on 08 Apr 2026 12:15 PM
Was watching Netflix when the internet went down, now there is 2 orange lights on our router have tried to rest it and still not working
when I go on my account it says there's an issue with broadband and then when I go to let's fix this it says it's working when it's not
Message posted on 08 Apr 2026 12:26 PM
Re: Can’t connect to WiFi
@Lulud
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
