Discussion topic: Can’t connect devices because modem box
This message was authored by: Jordan_
Hi
my devices are not working or connecting and I think it's to do with the modem box as the LOS light is off and the LAN light is flashing
Can you help me get this sorted please
thanks
This message was authored by: FLC
Re: Can’t connect devices because modem box
That's as it should be. LOS only lights in a fault condition & the LAN flashes with traffic. Indeed the fact it is flashing suggests traffic is flowing between the ONT & the router.
