3
This discussion topic has been answered Discussion topic: Can’t change SSID
This message was authored by: 3quid
Can’t change SSID
I want to change the SSID (and passcode) of my Sky Hub.
I have logged into the admin area. Got to the Wifi section.  Changed the name and passcode. Press apply and get sent to a disconnected page.
see screenshots.
I have tried doing this from phone, ipad and mac (ethernet connection). All fail. The SSID doesnt change and not does the passcode.
What am i doing wrong?
Re: Can’t change SSID
Using the Safari browser is known to be problematic for Sky Hub administration.
Avatar for 3quid
Ah ok. I'll try chrome.
if that's what the problem is, that is so shoddy. A huge corp like Sky and its router can't be administrated using safari? Not exactly niche!
Avatar for 3quid
Wow ok. That is why it wasn't working.
Sky hubs don;t work with Safari. Ridiculous but true! Thank you @TimmyBGood for your help. It is now solved
