Discussion topic: Can’t access internet WiFi issue
This message was authored by: Vivekkumar1
Can't access Internet
Re: Can’t access internet WiFi issue
@Vivekkumar1
The first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
▪️I AM NOT A SKY EMPLOYEE ▪️
