Discussion topic: Can not get through password entry when trying to connect my RING door bell to new Router.
Message posted on 02 Jul 2026 11:23 AM
Ring doorbell worked on previous router. New Sky Max Hub. Ring connects and works on iPhone hotspot. Fails at 95% when connecting to Sky Wi-Fi and reports incorrect password. WPA2-PSK. All other devices connect. Tried to select change Wifi settings in admin area of MySky but its not accepting the password there.
Message posted on 02 Jul 2026 12:08 PM
Re: Can not get through password entry when trying to connect my RING door bell to new Router.
@wardee72 you should be able to edit the password in the hub;sxsettings but check thst thecappis listing the correct hub in the My Devices section.
When entering Sky passwords it is extremly easy to misread them as Sky use letters like I & O and numbers like 1 & 0 which srecdead easy to mix up.
