27 Nov 2023 12:50 PM
Can I unplug my sky broadband box?
27 Nov 2023 12:52 PM - last edited: 27 Nov 2023 12:57 PM
Posted by a Superuser, not a Sky employee. Find out more@Miko1420 If you do you won't get any broadband/wifi
27 Nov 2023 12:54 PM
Posted by a Superuser, not a Sky employee. Find out moreI'm assume you are talking about the router.
Are you subscribed to Sky Broadband? If you are then turning of the router will prevent any of your devices from accessing the internet. If you are using another ISP to provide your broadband and have a router from them ( or your own router_ then you don't need the Sky broadband router.
27 Nov 2023 01:10 PM
I simply want to unplugg it to put a 4 plug extension in and then I will plug it back in
27 Nov 2023 01:20 PM
Posted by a Superuser, not a Sky employee. Find out moreThen you can unplug it, on you will just lose your WiFi for a couple of minutes whilst it's powered off and the powers back on again.
27 Nov 2023 01:30 PM
Brilliant, thank you 😊
