Discussion topic: Can I swap my sky router for a AX6600 WiFi Router (RAX70)?
This message was authored by: Matt166
Message posted on 09 Aug 2024 09:47 AM
I need to extend the range of my WiFi and want to purchase my own router. Can I connect the Netgear AX6600 WiFi Router (RAX70) without any issue?
Find out more
Message posted on 09 Aug 2024 11:52 AM
Re: Can I swap my sky router for a AX6600 WiFi Router (RAX70)?
If you want to replace the Sky hub outright the router needs to be able to authenticate via DHCP Option 61 on the WAN interface.
If you just want better WiFi you could connect the netgear router in series to the Sky hub and then just disable the WiFi radios on the Sky hub.
I am NOT a Sky Employee
