Discussion topic: Cable
This message was authored by: Carysaint
Cable
Can I use any ADSL cable as I have moved and need one for the sky broadband to work has it's been activated
Re: Cable
@Carysaint yes assuming you are not on a full fibre connection of course.
Avatar for Carysaint
Re: Cable
So it has to be sky cable then if full fibre ?
Re: Cable
@Carysaint no with full fibre the connection from the ONT to the hub uses an Ethernet cable with rj45 connectors rather than a dsl cable with rj11 connectors. You can use any cat5e or better ethernet cable you want up to 100m long and not lose speed.
This message was authored by: RenaReeder
Re: Cable
Thank you so much for the information.
