Discussion topic: Cable too short
This message was authored by: nikkib87
Cable too short
Hi We recently had fibre installed, and the ethernet cable that runs from the fibre box to the router is at least 2 metres too short. Pur fancy router is sat on the Doormat at the front door waiting for someone to kick it because the cable is too short 😂 What ethernet am I looking for on amazon, what will work with fibre? Cat 8? Im not very tech minded and dont want to buy the wrong thing.
Re: Cable too short
@nikkib87
Cat5e is fine, but Cat6A is likely to be the same price and theoretically 'better' for potential future FTTP speeds.
This message was authored by: Me134
Re: Cable too short
Cat8 is overpriced, unnecessary and frequently on Amazon not Cat8 anyway.
As above, go for Cat6 or Cat6A (Cat6A uses thicker strands so dissipates heat better but is only needed for really long runs). You'll be able to pick it up locally even from the likes of the Asda.
Not a Sky employee
Sky FTTP 500Mb to Max Hub
