Discussion topic: Cable loose
Message posted on 18 Sep 2026 02:16 PM
Cable loose
My cable is loose and dropping connection
Message posted on 18 Sep 2026 02:44 PM
Re: Cable loose
@Stha01 call Sky and report it so they can get it sorted.
Message posted on 18 Sep 2026 09:12 PM
Re: Cable loose
The wire is broke and can't watch sky
Message posted on 19 Sep 2026 05:07 AM
Re: Cable loose
@Lucy19741 if itsctge cable between the wall and yourcSky hub you can buy a replacement locally if you haveca partial fibre system delivered via a phone sovket you needca dsl cable with rj11 connectors. If youbare on full fibre you nedd an Ethernet cable with rj45 connectors.
Otherwise call Sky.
