3
This discussion topic has been answered Discussion topic: Cable difference between Sky and Virgin media
This message was authored by: gersfanuk
I am thinking of moving away from VM to the open reach network (possibly Sky).
I know i require a new line or reactivated externally not sure which, but was wondering if the internal cable from the wall can still be used and just replace the old router with new router or whether it is all new cables inside the house as well? My current setup is behind a media wall which has access to existing cables but not from the floor where I assume the new internal cabling would come from.
This message was authored by: Doc5907 Answer
Re: Cable difference between Sky and Virgin media
Hi @gersfanuk
When you switch to an Openreach fibre network you will need completely new cabling both externally coming into the house and all your internal cabling.
The Virgin cabling will become redundant and can be removed if desired.
Edit: if you have an ethernet cable running from you media wall to the Virgin ONT , you can of course use this cable and plug into openreach ONT, depending on where its located .
Sky Q 1TB UHD
LG TV
Sky Mobile
Hi @gersfanuk
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for gersfanuk
Thanks, I did think that but was hoping it wasn't
@gersfanuk
Historically Virgin laid a coaxial copper cable network, not optical fibre or ethernet.
