3
This discussion topic has been answered Discussion topic: Browsing History
This message was authored by: Mancafe
Browsing History
Does anyone know whether the Sky Broadband/WiFi account owner can check the browsing history of all devices connected to it in the household?
Re: Browsing History
@Mancafe
Certainly not possible to see all browsing activities (and even expensive commercial systems cannot see traffic inside apps)
Sky Broadband Shield allows creation of a custom blocklist but doesn't, I think, generate a log of access attempts which get blocked.
@Mancafe
@Mancafe
It's perhaps worth noting that ISPs essentially do the bare minimum to comply with UK law in this area by having mandatory age restrictions by default: they basically don't want to get into the potentially murky area of household internet surveillance (which is also a significant technical challenge anyway)
@Mancafe
If you really want to go down that route, you'd either need subscription to commercial per-device software installation (which is really rather intrusive) or a router/cloud service which intercepts and logs traffic: those are typically intended for school or similar environments and priced accordingly.
