Discussion topic: Broudband no
Message posted on 14 Jul 2026 11:28 PM
Broudband no
Internet keeps dropping and speed is running at 0.21 mbps
Message posted on 15 Jul 2026 04:04 AM
Re: Broudband no
@Jl1012
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
