Discussion topic: Brouband shield setting
This message was authored by: joannapilarska-
Message posted on 03 Aug 2025 02:07 AM
I can't change brouband shield setting. Whenever I use custom and all ,save setting all is ok but when i back its still PG I can't open some websites
Message posted on 03 Aug 2025 08:02 AM - last edited: 03 Aug 2025 08:13 AM
Re: Brouband shield setting
@joannapilarska- If you are having trouble and issues getting the Shield on your account to change and stick, then give sky a call, then can take a look at it for you and apply what you need, they will advise takes 2 hours for the changes but i always advise allow 24hrs for it to filter through the systems! Link below to the sky help on your subject!
Sky Broadband Shield | Sky Help | Sky.com | Sky Help | Sky.com
