Discussion topic: Brord band
Message posted on 26 Apr 2025 07:45 PM
Brord band
My Internet has been on and off for the last week but when I ask u to test it seems to work but its not our end
Message posted on 26 Apr 2025 07:48 PM
Re: Brord band
@Mandy2480
If you’re not already aware the Sky Community is a customer led discussion forum where Sky customers are available to help other customers and you aren’t contacting Sky Customer Services.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
