Discussion topic: Brooadband charge
This message was authored by: Haze8
Brooadband charge
My 2 year broadband contract has expired.  It is now £49 pcm.  Alot.  Should I switch to another broadband provider ?   Thoughts please.  Thank you
Re: Brooadband charge
@Haze8
Your discount has finished.
The usual reason for a bill increase, other than the usual annual price increase in April, is that your discounts have ended.
Perhaps compare the latest bill with previous ones to see where it differs.
If your discounted minimum term has ended or its ending soon the best new discounts are still normally acquired by contacting Sky and negotiating or potentially amending your package which will require a new 24 month minimum term contract.
’Significant’ discounts seem harder to come by these days so if you’re offered something acceptable be prepared to agree to it there and then because if you decide to think about it the offer is unlikely to be available when you call back. Also remember you’re not a new Sky customer so don’t expect anything on a par to a new customer deal.
See this link…
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
If you decide it’s no longer value for money and you’re thinking of changing providers remember that at the end of their minimum term you'll be in the same position with that company at which point you'll be able to return to Sky and benefit from the new customer discounts available at that particular time.
▪️I AM NOT A SKY EMPLOYEE ▪️
@Haze8  Have you called Sky to see if you can negotiate a new deal?
