Discussion topic: Broadband wont work
This message was authored by RebeccaS123 This message was authored by: RebeccaS123
Broadband wont work
Hi guys, came home from work today and my Internet connection is down. I have done all the usual things, turned it off at the mains, hit the reset button, checked all cables but still won't connect. Have two green lights either side of an orange light on the router. Anyone have a similar issue and have any other advice?
Thanks a mill
Re: Broadband wont work
@RebeccaS123 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
RebeccaS123
Yes did the broadband test already and just says problem with my connection and tells me to do all the steps ive already done.
I am going to leave it for this evening as amd try tomorrow as I keep getting directed to the options to trouble shoot nothing is working
Thanks for the reply
@RebeccaS123  Do you have the ability to call Sky for them to to book an engineer for the fault you have?
RebeccaS123
Yes I will probably call them tomorrow during my lunch break from work if it's still not resolved
Thanks again for your help
@RebeccaS123   If you are not able to get through come back to us and we can escalate it for you.
