Discussion topic: Broadband/wifi
This message was authored by: DanielleHaines
Broadband/wifi
Having connection issues
Re: Broadband/wifi
@DanielleHaines
I don't think essential maintenance would be done on a Sunday night which would be a likely cause between midnight and 7am on other nights.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
