Discussion topic: Broadband/wifi off
This message was authored by: Bon12
Broadband/wifi off
Problem started at about 12:50am, Have performed diagnostics, cycled off, checked cables, reset hub etc.. still no Internet or voice light on, on the router.
Re: Broadband/wifi off
@Bon12
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If you are still having broadband problems use this link to check to see if there are any issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
