Discussion topic: Broadband went down earlier and the router has no lights
This message was authored by Looking4datbutton This message was authored by: Looking4datbutton
My internet went off earlier and a while later I realised all the lights on the router were off.
I checked to make sure the wall socket was working and it is.If I press the reset button the power light comes on then goes off after 10 seconds,the other lights don't come on at all.
Any advice or tips or is my router jist done?
Re: Broadband went down earlier and the router has no lights
@Looking4datbutton  So there is no power light on at all on the router and it is not red?
This message was authored by nstokes This message was authored by: nstokes
Try another wall socket and if same issue you know it is not a socket issue
Sky Q 2TB, 2 x Sky Q mini
