Discussion topic: Broadband upgrade
Message posted on 24 Feb 2026 05:09 PM
Broadband upgrade
Message posted on 24 Feb 2026 05:19 PM - last edited: 24 Feb 2026 05:20 PM
Re: Broadband upgrade
@Juliemark5352 Is your old copper connection not still up and working? Have you tried it back on it.... Your new ONT that was fitted what are the light colours and names, OR Install would be Power Solid Green, Pon Solid Green, and the Lan flashes connected to the Hub, the LOS has to be out/not lit!
Link below to help....
Message posted on 24 Feb 2026 06:28 PM
We think it has been sorted now as all lights are solid now and it seems to be working but my account says there's a problem still. I know I can rewire back to the copper wire if needed but as its in the other room now, I don't know if the wire will reach but hopefully its sorted now. Just got to got the installer to phone us and update it on the account. Thanks
Message posted on 24 Feb 2026 06:31 PM
@Juliemark5352 So you are aware, once your Fibre cable goes live, then about 30 mins later your copper cable will be as dead as a dodo!
Message posted on 25 Feb 2026 08:55 AM
No I want aware of that. They haven't put it as fixed at the moment. They are saying they are still working on it but it seems to be working since last night but the engineer is still waiting to be called to say it's done so they haven't updated the system. Hopefully it won't be needed again anyway but thanks for the info.
