Discussion topic: Broadband under 5mbs
This message was authored by: Tonyhandley1
Message posted on 17 Jun 2024 08:49 PM
Just had new router and sky connection after being with BT (we got a low 15mbs) and sky sold us new broadband and speeds but nothing has worked. We can't watch tv or event open apps on phones as the speed test shows just 4/5 mbs!
This message was authored by: JPR007
Message posted on 17 Jun 2024 09:28 PM
Re: Broadband under 5mbs
Are you on an ADSL connection? Those speeds sound like you are. It would be very unlikely to get any real difference in speed between ISP's as they all use the same physical connection/line to the property.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
