Discussion topic: Broadband times
This message was authored by: Jules_21
Broadband times
Can I set my broadband so it can only be used at certain times of the day say like I'm at work and don't want it to be used whilst I'm not there
Re: Broadband times
@Jules_21
Not directly (apart from putting the Hub on a timer switch at the power socket, which isn't good for it)
The WiFi Max subscription supplement has individual device control.
https://www.sky.com/help/articles/sky-wifi-max-parental-controls
Avatar for Jules_21
Re: Broadband times
Thank you the timer thing is to easy for others to unplug and then it's off... Is max available to everyone?
