Discussion topic: Broadband speed
This message was authored by: peterlinley
Broadband speed
Hi I should be getting guaranteed 1000mbps but keeps dropping down below 300mbps
Re: Broadband speed
@peterlinley Have a look on your account, the history off connection to the router should be there.
This message was authored by: peter-marlow+1966
Re: Broadband speed
If you  have sky gigafast broadband  it's  900mps  to the hub, but you are meant  to have 600mps minimum  as i have that it's  is full fibre broadband to the property, as you are only getting  300mps i would  ring sky and get them to  do checks on your  broadband
P c marlow
Avatar for peterlinley
Level 0 icon
Re: Broadband speed
WiFi speed shockingly low too average 50mbps
Re: Broadband speed
@peterlinley If that is what you are seeing on your account, then run the diagnostic to see what it reports. Have you just joined sky, or upgraded from fttc to fttp?
Re: Broadband speed
Do you have any boosters for the wifi, i would definitely  give sky a ring about that, i can only tell you from my personal  point as a fellow customer on here, i  have the wifi  max hub and a booster  pod and have no problems  with  my wifi
P c marlow
This message was authored by: brianholt
Re: Broadband speed
@peterlinley what package are you on ? What's your guaranteed minimum speed that sky will have provided when you joined ? Finally how are you connecting wired or wireless ?
Like you I am a fellow customer trying to help so please provide as much info as possible
Sky Q : Sky Gigafast : Sky Talk Anytime : Panasonic JZ2000 OLED
