13 Jan 2023 05:10 PM
13 Jan 2023 07:22 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you are testing over WiFi on a device thats connecting to the 2.4ghz WiFi band then yes its quite normal. If you want gigafast speeds you'll need to use an ethernet cable or invest in a higher spec 3rd party router.
