This discussion topic has been answered Discussion topic: Broadband speed test before purchasing
Message posted on 15 Sep 2025 06:05 PM
Hello!
I am tempted to switch to Sky Broadband as the price is a lot better then my current provider and the internet speeds looks promising too!
However I want to make sure I can get the speed I pay for.
If I go to a physical store of Sky can they see if Full Fibre is available in my area?
Many thank!
Message posted on 15 Sep 2025 06:15 PM
You should get 80Mbps with a guarantee of 60Mbps. There is no full fibre
Message posted on 15 Sep 2025 06:09 PM - last edited: 15 Sep 2025 06:10 PM
Re: Broadband speed test before purchasing
Could you enter your full address in the link below and post the table and notes after removing your address from the image
Message posted on 15 Sep 2025 06:10 PM
There's no need to do so.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate which broadband provisioning type is applicable.
Message posted on 15 Sep 2025 06:11 PM
Hope this is okay! I can't see my address on the screenshot so that should be fine
Just posted the picture!
Message posted on 15 Sep 2025 06:17 PM
Damn that sucks,
Been working from home and the internet is terrible.
Downloading games after work is basically an overnight job. Wish Sky had full fibre here.
Thank you tho!
Message posted on 15 Sep 2025 07:19 PM - last edited: 15 Sep 2025 07:26 PM
Unless it's CityFibre?
Message posted on 15 Sep 2025 09:41 PM
For some reason I can't post the picture but it literally says:
Great news! You can connect to the CityFibre network
Message posted on 15 Sep 2025 09:58 PM - last edited: 15 Sep 2025 10:00 PM
In that case Sky can probably offer their whole range of FTTP speeds plus the new (and completely unnecessary) 2.5Gbs and 5Gbs bands. Apparently they don't have presence across the entire CityFibre network though.
Message posted on 15 Sep 2025 10:23 PM
I'm glad to hear tbh!
Even if it's a small chance I'm willing to take it. Currently on 70Mbps atm.. I struggle with working from home as I randomly drop connection.
As I'm near one of their stores this weekend I might just pop in and see if they can see the range I can get
Message posted on 15 Sep 2025 10:34 PM
@Shiya You should be able to see all off what you can get on sky.com, your address will say what sky is able to offer you from FTTC only, or FF all the way on a CF connection. If CF is not available to you then FTTC at the 80/20 split would be as you have currently!
Message posted on 15 Sep 2025 10:43 PM
I think it shows every speed that they have available! So I guess I can nearly go ahead with going to 900Mbps
Message posted on 15 Sep 2025 10:50 PM
@Shiya Would say so, procedure would be a OTS operation, sky take care off everything, Fibre install and phone connection landline if needed, switchover, contacting your old provider, you need to do nothing at all, just sit back and hope it all goes smooth! Speed package if you select the 900Mb/s then should be 900/900 symmetrical and that is a CF only option for sure think it will show that in the speed if you click on it!👍
Message posted on 15 Sep 2025 11:00 PM
Thank you for the information. My partner and I need to figure some stuff out with our old provider but we will be okay so switching very soon
