Discussion topic: Broadband speed slow
Message posted on 16 Apr 2025 10:09 PM
Message posted on 17 Apr 2025 07:27 AM
Re: Broadband speed slow
@Ian3180 if you are measuring speed on a device connected by wifi the explanation is almost certainly down to slow wifi in your home. To test speeds to the hub you have to use a known high speed connection like a direct gigabit ethernet link.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
