1
This discussion topic has been answered Discussion topic: Broadband - should I leave BT and join Sky
This message was authored by: Njc68
Trying to decide if I should leave BT 500Mb full fibre  and become a Sky customer also with the 500Mb service with a saving of £20 per month
This message was authored by: jamesn123 Answer
Re: Broadband - should I leave BT and join Sky
@Njc68
It depends on your use case really. If you are a heavy user or struggle with WiFi coverage/require a booster from BT currently then I would recommend you avoid Sky as this will likely just get worse for you.
I am NOT a Sky Employee
@Njc68
