Discussion topic: Broadband rubbish!
This message was authored by: Claire976
Broadband rubbish!
I recently changed from BT to sky which uses the same open reach point and my internet is so bad. Can't be on 2 phones, have Netflix playing it's ridiculous. Can't even be on 1 phone and Netflix. Says my speeds are 67mpbs and my broadband is fine but doing tests of my own they are sitting between 17-25mpbs. What can I do?
Re: Broadband rubbish!
@Claire976
Using 3rd party speed tests can be hit or miss. Best using a ethernet device using fast.com
Could you post your router stats as below
Avatar for Claire976
Router Statistics
System Up Time: 1330:59:26
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 265673335 739280261 0 210639 7467133 1330:57:20 LAN Up 14625261 958465 0 4504 0 1330:59:26 WLAN (2.4 GHz) Up 286725828 108464610 0 907915 112506 1330:57:36 WLAN (5 GHz) Up 494167745 186083811 0 0 0 1330:57:33
Broadband Link Downstream Upstream Connection Speed 71437 kbps 20000 kbps Line Attenuation D1(10.2 dB) , D2(24.8 dB) , D3(38.8 dB) U0(3.0 dB) , U1(18.7 dB) , U2(29.4 dB) Noise Margin 3.2 dB 8.4 dB
