Discussion topic: Broadband problems
This message was authored by: Jenny130
Broadband problems
Broadband not working. I have just agreed to move over to EE BROADBAND next week, the day sky found out we have had nothing but issues with our broadband
Re: Broadband problems
@Jenny130
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
@Jenny130 No doubt then EE can sort it all out for you when you get connected to them! Left EE back in Mar to return to sky, they just do not have a clue. If you say what is going on at present but there are a lot off unforseen issues at present with Broadband that may just be storm related!
