Discussion topic: Broadband password
This message was authored by: Barb63
Message posted on 31 May 2025 10:23 AM
Broadband password
Hi. I have just had a new sky router installed but would like to change my password back to my previous one
Message posted on 31 May 2025 11:12 AM - last edited: 31 May 2025 11:17 AM
Re: Broadband password
@Barb63 What sky hub do you have? also see the tips link from above if it saves you time! Depending on the hub check out both links!
Find, change or reset your WiFi password | Sky Help | Sky.com | Sky Help | Sky.com
