Discussion topic: Broadband outages
Message posted on 27 Nov 2025 12:27 AM
Broadband outages
I have had multiple broadband outages (4) in the space of a few weeks. Each time it is in the late evening. This is becoming a really annoying issue and quite frankly the worst internet service I have ever had
Message posted on 27 Nov 2025 05:04 AM - last edited: 27 Nov 2025 05:34 AM
Re: Broadband outages
@Fedup1996
If you have broadband issues between midnight and 0700 it’s likely to be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See the pinned post at the top of the Broadband board from Sky
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
If it's earlier than that, even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
