Discussion topic: Broadband outage - PR1
This message was authored by: LinziHolding
Current unable to work due to no broadband in PR1.
My Sky will not complete connection check
Re: Broadband outage - PR1
@LinziHolding
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
