2
This discussion topic has been answered Discussion topic: Broadband not workinv
This message was authored by: Baillieston41_
My broadband for months keeps disconnecting- I cannot get my emails or messages and this has been going on now for months.
it goes off every 10 seconds
Re: Broadband not workinv
@Baillieston41_
Avatar for Baillieston41_
Can someone pls tell me how to get broadband working - it's going off non stop.
I have to reboot boxes.
even the tv service is effected when in youtube
@Baillieston41_
