Discussion topic: Broadband not working
This message was authored by: Hayleyb2k19
Broadband has been cutting in and off for a while but this time won't reset. Check service checker says it's fixed when clearly an issue with sky. Fix it or ill be taking my gold vip membership elsewhere
Re: Broadband not working
@Hayleyb2k19
You aren’t actually contacting Sky by posting here as this is a customer ▶️ customer discussion forum where we try to assist other customers.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
Avatar for Hayleyb2k19
Re: No tv no internet
All i am seeing is the same answer to the same questions when clearly it is sky that has the issue
