Discussion topic: Broadband not working
Message posted on 27 Jun 2026 02:34 PM
The WiFi is not working at all. We have turned it all off and back on but no joy
Message posted on 27 Jun 2026 03:13 PM
Re: Broadband not working
@Yvonne127
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
