Discussion topic: Broadband not working
Message posted on 14 Jun 2026 08:14 AM
My broadband isn't working
Message posted on 14 Jun 2026 08:18 AM
Re: Broadband not working
Not much information there to work with.
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
