Discussion topic: Broadband not working
Message posted on 05 Jun 2026 12:51 PM
It's constantly cutting out, works for around 6 mins and then stops
Message posted on 05 Jun 2026 01:04 PM
Re: Broadband not working
@Jadec93
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
