Discussion topic: Broadband not working
Message posted on 02 Jun 2026 10:23 PM
Now Tv is not loading, neither are Netflix, HBO max and Prime tv.
I have disconnected my Sky Hub completely, run all available checks through your Sky app and online checks, and your app still insist my broadband/Wifi service is fine at 27mbps
Having worked in my local BT exchange, I find this incredibly insulting and I'm paying for an inferior product that's clearly not working...
Message posted on 03 Jun 2026 05:11 AM
Re: Broadband not working
@Kite5
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
