Discussion topic: Broadband not working
Message posted on 02 Jun 2026 04:41 PM
WiFi not working
Message posted on 02 Jun 2026 05:33 PM
Re: Broadband not working
are you able to provide more details please ? what setup do you have i.e Full fibre or copper ? and do you ahve a red light on the Sky hub or ONT
Sky Full Fibre 500mbps
@Cardy1
Even if you’ve already tried it use this link to check if there are any broadband issues locally that may identify a known fault, perhaps affecting multiple households ~
Its always worth rechecking it as the Service Checker doesn’t necessarily disclose a problem immediately and there is up to an hours delay before it picks up a lost connection so perhaps try it again later.
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
