Discussion topic: Broadband not working
This message was authored by: HD8412
My broadband was working totally fine and then the TV paused and now the internet is down, despite checks saying everything is ok, all lights on the hub are green except the internet one which is either off or just a very very feint green. Can anyone help please?
This message was authored by: harrington985
Re: Broadband not working
Having the same problem to.
Avatar for HD8412
There's nothing I can see online to say there's an outage anywhere, what about you? Where are you??
@HD8412
Did you run this line test:
Avatar for HD8412
Hi, I just went through all the steps and it's the PON light on the ONT that isn't on. Is this the problem and do you know if there's a way to fix this please? I've done all the switching off/on and moving cabling etc
The light being off will be the issue, as you have rebooted it if it hasn't come back on by tomorrow you will need to report this to Sky as there might be a fault somewhere.
Avatar for HD8412
I've booked an engineer for Friday morning!! Thanks for your help, now it's time for the cavalry!!
