Discussion topic: Broadband not working
Message posted on 01 Feb 2026 10:20 PM
Sky WiFi not working any other have issues
Message posted on 01 Feb 2026 10:25 PM
Re: Broadband not working
Any help green light not on WiFi box
Message posted on 01 Feb 2026 10:29 PM
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
Message posted on 01 Feb 2026 10:34 PM
Have reset the box and powered off no luck
Message posted on 01 Feb 2026 10:43 PM
@Paul22g1 See the links that @caesarome has posted up for you, but if your light has just gone off will take a few hours before it throws you a bone to possibly why if an area type fault is involved!
Message posted on 01 Feb 2026 10:50 PM
The middle green light not showing. Have checked all cables etc. was working and just stopped. Have disconnected power etc. other 2 green lights on
Message posted on 01 Feb 2026 10:51 PM
@Paul22g1 About the lights is below!
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
Message posted on 01 Feb 2026 10:52 PM
Yes very slow or down
