Discussion topic: Broadband not working
Message posted on 22 Jan 2026 10:28 PM
Message posted on 23 Jan 2026 05:28 AM
Re: Broadband not working
@Chriswaring
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
