This discussion topic has been answered Discussion topic: Broadband not working
Message posted on 21 Jan 2026 03:09 PM
My broadband has dropped out sky checkers say there's no issues but we can't connect any ideas?
Message posted on 21 Jan 2026 03:14 PM
@Kathryn+Wardlaw
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@Kathryn+Wardlaw
Message posted on 21 Jan 2026 03:47 PM
Re: Broadband not working
I did all that several times and ended up having to call sky. Appears there was a network issue that wasn't showing in there checks! X
