Discussion topic: Broadband not working
This message was authored by: Shamilaisra
The broadband is still red with all the steps I followed it's still not working and this keeps happening and I've had enough now the speed and the internet not working well and it causing a lot of issues
Re: Broadband not working
@Shamilaisra
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
