Discussion topic: Broadband not working
Message posted on 17 Dec 2025 10:21 AM
I've had a power cut & now my broadband isn't working. I've tested everything but still nothing. It has been playing up for a few days now though.
Message posted on 17 Dec 2025 10:30 AM
Re: Broadband not working
Presuming the power is back on the first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
